Bosch Dishwasher SGV46M03GB/36 Not washing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch Dishwasher SGV46M03GB/36 Not washing
  • #68750
    Bernie
    Set the spray arms facing front to back close door start machine, fills tries to wash, the top arm has moved but the bottom is still in the same place.
    It would appear that the motor is not running as fast as it should (it just does not sound like it got any oomph) with the right side panel off and watching the fan inside the motor, it seems to be turning slowly. I know you can get an optical illusion but stopping & starting machine while watching motor fan it does not really get going, tried new capacitor did not help. Also tried new impeller jug just in case it was not getting enough water that did not help either.
    Has anyone had this problem is it the motor?
    Thanks for looking
    Bernie
    #372661
    Re: Bosch Dishwasher SGV46M03GB/36 Not washing
    Bernie wrote:Has anyone had this problem is it the motor?
    Common problem Bernie and its the water diverter in the heater box that has failed. The cure is to replace the heater unit (part No 498623).
    HTH? 😀
    #372662
    Bernie
    Thanks for the quick reply Martin
    Bernie
