Bosch dishwasher SGV56A13GB/22 anti flood enabled
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch dishwasher SGV56A13GB/22 anti flood enabled
  • #31591
    peeb
    hello there , i wonder if you could possibly help?my bosch integrated dishwasher SGV56A13GB/22 drain pump wont stop running.
    i have been on a number of threads which explain the anti flood device kicking in owing to water in the tray , and this is exactly what im experiencing. the pump wont stop running , water in tray , even with door open etc.
    i have taken the panel off the lh side of dw and can see water and a scale residue coming from a specific point on the pressure chamber indicating the leak. i am assuming if i replace the whole pressure chamber then it will stop the anti flood kicking in !, ?
    please help , many thanks !!
    #231776
    Re: Bosch dishwasher SGV56A13GB/22 anti flood enabled
    Most likely the leak is caused by water backing up in the chamber due to the hose in the front left corner being choked. Remove it and clean thoroughly, likewise the pressure chamber and you should be back in business.
    Power off if doing this yourself.
    peeb
    Penguin45 wrote:Most likely the leak is caused by water backing up in the chamber due to the hose in the front left corner being choked. Remove it and clean thoroughly, likewise the pressure chamber and you should be back in business.
    hi
    thanks for your quick reply .i will certainly try this out tomorrow and let you know how i get on.
    (hopefully get some brownie points in with the good lady!!)
    kind regards , peeb.
    #231778
    peeb
    hi
    RESULT!!!!!!!!!!!!!!
    you are a LEGEND penguin45! i cant thank you enough for you advice.
    i did as you said by cleaning the pressure chamber. i never realised that i had to take the whole chamber off to get to the bit at the bottom with the float switch parts in that were all covered in fat.bit of a game but i took my time and it is working fine.
    thanks a million.saved me a packet.
    peeb
