Bosch Dishwasher SGV56A13GB Noisey
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch Dishwasher SGV56A13GB Noisey
  • #36399
    laserdave
    I have a Bosch Integrated SGV56A13GB dishawasher which is pulsing the cold water pipes in the house on fill there are are about 5 – 6 loud bangs I have removed the left hand side panel and noticed the orange float in the pressure chamber goes up and down
    Any ideas what the problem is
    #250861
    nationalhomecare
    Re: Bosch Dishwasher SGV56A13GB Noisey
    Hello!
    It is probably the hose from that pressure chamber to the sump is restricted with grease/gunge, its a push fit hose about 10″ long and will need to be removed and cleaned.
    What is happening as it fills is that the water is backing up in the hose and operating the overfill/safety float, the orange thing you can see operating, causing the inlet valve to open and close repeatedly.
    Always remember to disconnect the appliance from the supply before carrying out any investigation 😉
    Regards
    NationalHomecare
    #250862
    laserdave
    Many thanks i will give thia a try i did remove the pressure chamber and rinsed it out but the problem still remained.
    #250863
    laserdave
    I have cleaned the pipe from the pressure chamber to the pump this has cured the problem.
    Many Thanks for your help and advice
