bosch dishwasher sgv57t03gb/07
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bosch dishwasher sgv57t03gb/07
  • #67882
    kwaremont
    cleared pressure chamber because of overfilling removed water from base, cleared fault now sticks at end of programme with 1 minute to go , doing wash action, the heater does work any ideas thanks.
    #368857
    Re: bosch dishwasher sgv57t03gb/07
    Could be a drain or filling time out? If it only happens on an ‘Auto’ cycle then it’s likely a Turbidity Sensor problem. You mentioned “overfilling” and that could be a PCB issue as well as a blocked pressure system? But if it now fills OK and in reasonable time you might get away with that. Does the circulating pump burst into life before all the water has drained into the tub?
    #368858
    kwaremont
    thanks martin , as a blocked pressure chamber is a common fault i carry one that is allready cleaned out as they all look the same , i wonder if the one i have fitted is not compatable with this model & the water level is too low allthough the heater does come on.also could the 1 on the display be a fault code and not 1 minute
    #368859
    As long as the Pressure Chamber is identical in every way it would be fine. There are no error codes on this model so the number 1 in the window represents 1 minute remaining (i.e default time-out indication)
