Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch Dishwasher (SGV57T03GB/07)
- This topic has 7 replies, 3 voices, and was last updated 5 years, 1 month ago by
martfoxy.
February 20, 2021 at 1:53 pm #99176
martfoxy
ParticipantThere was a loud ping noise that sounded like a spring breaking on the door of our dishwasher (Bosch SGV57T03GB/07). I pulled the dishwasher out from the kitchen unit and discovered half a spring hanging down underneath. I have ordered another spring. Will there be another spring the other side – maybe that has gone as well.
I can’t see a way of getting to the spring from the side to replace it – does the dishwasher have to be laid on its side or back to get to the spring? I can’t see a video for this model only ones where its easy to get to from the side.
Thank you
February 20, 2021 at 1:58 pm #475267electrofix
Moderatoryes springs on both sides
https://www.bosch-home.co.uk/supportdetail/product/SGV57T03GB/07#/Tabs=section-spareparts/
February 21, 2021 at 7:41 pm #475268andyjawa
Participantmake sure too that the strings part 165298 are still in one piece.
March 11, 2021 at 9:25 am #475269martfoxy
ParticipantThanks very much for your help. I have replaced the broken spring, both strings are ok.However the door is leaking now a bit from the lower corners. Do I need to replace both springs to even the tension or does the door seal need replacing or could it be the lower door seal (how do I tell).
Thank you
March 11, 2021 at 10:08 am #475270electrofix
Moderatorgive things a good clean. often find gunk in the corners and under the lower lip of the door
also check all the holes of the bars are clear
March 17, 2021 at 9:38 pm #475271martfoxy
ParticipantThanks very much for your advice. Gave all bits a good clean and so far seems to have fixed the leaking.
March 23, 2021 at 8:55 am #475272martfoxy
ParticipantThere are small areas of wet again under the corners of the dishwasher at the front. I notice after use there is condensation on the outer side of the door seal – I wonder if this is running down causing the wet patches?
March 23, 2021 at 10:03 am #475273electrofix
Moderatorgive the door and seal a good clean. pay attention to the door as the stainless steel can get build ups that may comprimise the seal
also check all the bars. make sure they are clean and all the holes are free from debris
