bosch dishwasher SHV55MO3GB/79
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bosch dishwasher SHV55MO3GB/79
  • #66635
    johno1998
    The dishwasher will run through its full program washes and heats up but stops with one minute left on display. And the top arm does not rotate. 😕
    #364731
    Re: bosch dishwasher SHV55MO3GB/79
    Stopping at 1 min means it is timing out for some reason. Could be water level problem, blocked pressure chamber etc etc. Top spray arm not rotating could likely mean that the water deverter valve in the heater box has failed and jammed on bottom spray only. 🙁
    #364732
    johno1998
    was blocked water tank so couldnt fill or drain
