bosch dishwasher sms40c02gb/03
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bosch dishwasher sms40c02gb/03
  • #88413
    eng14
    hi all,i went to this d/w that was faulty.it comes up with check water after the drain pump on,changed reed no good,check drain fine.what am i missing,richard.thanks.
    #437998
    Re: bosch dishwasher sms40c02gb/03
    did the unit start the programme and fill ? if no
    this unit uses a 3 phase drain pump and senses the current to the pump to determine if the unit is empty. if the pump is worn the current increases and the unit wrongly assumes it is still full
    eng14
    many thanks dave
    #438000
    nomadPaul
    Is this at start up ? The start up procedure for these machines is as follows.
    After start button operated:
    Drain pump runs for approx 1 min.
    Pause
    Heat pump runs for approx 10secs.
    Pause.
    1 sec burst of water.
    Pause
    Then it starts filling.
    You can get a fail to start with something as simple as the drain pump access lid being loose or out of position.
    Hope this helps.
