Have a Bosch dishwasher model number SMS50E06UK/01 which has an intermittent fault and a code is displayed on the control panel. The code is E14 and appears at the beginning of the intensive wash cycle. Any advice appreciated.
‘e14’ is a flow meter fault.. It the reed switch on the side chamber [left side] monitors water intake. From memory its called a contact on the parts info and is available as a separate part from the side chamber. hth
Thanks for the help…..I did suspect that it may be the flow meter as after watching the dishwasher for almost an hour no E14 fault appeared. Where can I find fault codes for new range Bosch equipment?
