Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch Dishwasher SMS50E22FF 2013 Intermittent fault
- This topic has 11 replies, 3 voices, and was last updated 2 years, 4 months ago by
BarnacleBill.
November 15, 2023 at 10:45 am #102381
BarnacleBill
ParticipantLooking for help with this.
Old machine (10 years old) but used only 2 months a year, this fault has just started.
Refuses to fill and start cycle and both rinse aid and tap closed led’s flashing.
Left unplugged from the mains for a few weeks, reconnected and it works fine for a few cycles
then the same fault returns.Any advice much appreciated!
November 15, 2023 at 8:41 pm #488562Inverappin
ParticipantPossibly leaking into the base, activating anti-flood. Switching off for a few weeks allows for leakage to evaporate, hence will run again, but only until possible drip leaks enough to re-trigger anti-flood.
Next time it refuses to run, power off, tilt machine back 45° to drain. If it then runs ok, it’s looking more likely it’s the above.
November 16, 2023 at 6:37 am #488563BarnacleBill
ParticipantMany thanks for the advice, I’ll look into that!
November 16, 2023 at 9:49 am #488564electrofix
Moderatorit will be a leak
remove the lower outer door wrapper
remove the kick strip at the bottom
this will gove you access to a metal cover held on with 2 torx 20 screws.
remove this and look for water in the base
mop this out and the unit shouls run
now run the unit with the covers off but watch with a good torch and look around the base for leaks
November 16, 2023 at 1:25 pm #488565BarnacleBill
ParticipantThanks for your reply Dave, however I removed the covers and checked, bone dry no sign of any water.
November 16, 2023 at 9:01 pm #488566electrofix
Moderatorhave you always unplugged this or switched off at the socket between uses ?
November 17, 2023 at 6:49 am #488567BarnacleBill
ParticipantAlways left plugged in and switched on at supply.
Before the two lights flash there is a sound of relays on the power unit operating briefly!November 17, 2023 at 9:26 am #488568electrofix
Moderatorone of the problems with a lot of appliances these days is they are not off. your unit has been in standby for 10 years. So even though your not using it the power supply has been on and in use. its possible the power supply capacitors have degraded and are causing your problem
With all modern appliances turn off at the socket, not only to make them last longer but also to stop the small amount of energy they use
At current prices your dishwasher is costing about £12 a year for doing nothing
November 17, 2023 at 12:54 pm #488569BarnacleBill
ParticipantThanks for that info Dave, actually it is used in a rental cottage so although on during the summer for around 3 months, it’s off for the rest of the year ie unplugged.
Just wonder if I can remove and open the power module to see if those capacitors are faulty and I can replace them.
I don’t like throwing stuff away if I can fix it.
Thanks again for your advice.
BillNovember 17, 2023 at 6:03 pm #488570electrofix
Moderatoryes you can open it
its on the right side rear. the mains plug is plugged directly in it
November 18, 2023 at 3:04 pm #488571BarnacleBill
ParticipantHere’s the power board and both capacitors test fine….think I will have to give up trying to fix it now!
Thanks for the advice, appreciated!
BillNovember 18, 2023 at 3:08 pm #488572BarnacleBill
ParticipantSorry, can’t send the photo as it’s too large a file.
