BOSCH DISHWASHER SMS50T06GB/06 NOT DRAINING
Home Forums Public Support Forums Help And Support Dishwasher Help Forum BOSCH DISHWASHER SMS50T06GB/06 NOT DRAINING
  • #94412
    BROOKER25TDI
    Hi, I HAVE A BOSCH DISHWASHER WHICH IS NOT DRAINING, I HAVE CHECKED ALL FILTERS AND HOSES FOR BLOCKAGES BUT ALL CLEAR, I HAVE REPLACED DRAIN PUMP BUT STILL NOT DRAINING. REMOVED PUMP FEED PIPE TO WATER MATRIX AND LET IT RUN PRE RINSE CYCLE WHICH IT COMPLETED OK WHEN NOT CONNECTED TO WATER MATRIX. I THEN THOUGHT MUST BE A BLOCKAGE IN MATRIX OR DRAIN HOSE, HAVE CHECKED THESE AND NO BLOCKAGES, ANY THOUGHTS OR IDEAS AS WHAT TO DO NEXT WOULD BE APPRECIATED.THANKS IN ADVANCE
    #457285
    Re: BOSCH DISHWASHER SMS50T06GB/06 NOT DRAINING
    is the pump running ?
    BROOKER25TDI
    HI Dave,
    THE PUMP IS RUNNING, WHEN PIPE FROM DRAIN PUMP IS TAKEN OFF WATER MATRIX AND PUT IN A BOWL IT COMPLETES CYCLE AND DRAINS OK, IT SEEMS WHEN CONNECTED BACK TO WATER MATRIX IT DOESNT SEEM TO HAVE ENOUGH POWER TO PUMP WATER OUT AND CODE E25 SHOWS UP.
    #457287
    just a point CAPITAL LETTERS are the forums way of shouting
    you seem to have covered all the bases but I would look again at the hoses. bear in mind there is water getting through so if there is a blockage its only partial so blowing air down them is unlikely to clear it.
    you have changed the pump so if there is no blockages and the pump is ok the only thing left is a board fault
    BROOKER25TDI
    Ok thanks for advice
