Bosch dishwasher SMV40C30GB/49 FD9901
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch dishwasher SMV40C30GB/49 FD9901
  • #101865
    dunston
    Hope some can help.
    The dishwasher will switch on – will select a program – wash light (brush symbol) and floor LED flashes then after about 10 seconds both lights go out and the tap light flashes. Nothing runs. No water in the base.
    Operating the anti flood float the drain pump runs for about 20 seconds.
    Guessing something is open circuit, (simpler to a E19 error on different models. This model does not have a dispenser valve)
    The customer did say for a couple for weeks he would close the door – it would bleep but not start then he would open the door, press start – close the door and it would start.
    Anyone had this problem.
    #486495
    kaibart
    I would check contact, flow through sensor then drain valve
    #486496
    dunston
    I know the flow thro sensor 00611317 – They usually fail while filling – its not filling.
    What’s the drain valve? do you have a part number?
    #486497
    kaibart
    I had one fail yesterday and it filled and started to wash after a few minutes the check water light came on so start with contact flow through sensor
    #486498
    dunston
    Its not filling.
    #486499
    you dont say if it pumps at the beginning or not so i assume it does not
    so
    check pump for blockages
    if ok check door sw
    dunston
    Nothing runs at the start. The drain pump will run by operating the anti flood float.
    I’ll check the door switch.
    I’ve repaired dozens of these dishwashers but the flashing tap light is something I haven’t come across before.
    #486501
    if water light is steady its a fill fault
    if its flashing it could be any other fault
