Called out to Bosch dishwasher SMV88TD00/07 with fault code E07, fault shows as drying fan error code but tested ok. Fault code appears as soon as the program has started. Checked continuity on heater, pump and drying fan all checking ok. Cleared obstructions in sump and pump. Any help appreciated.
E:07 means fault in the drying system. This model has the zeolith drying system so if the drying fan is ok I’m guessing the zeolith heater may have failed.
