Bosch Dishwasher SPV40C10GB/32 FD: 9511
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch Dishwasher SPV40C10GB/32 FD: 9511
  • #102212
    DIYer
    Hello I used my Bosch integrated dishwasher twice yesterday. I went to use it again and the tap symbol came on. I have cleaned the inlet filter, checked to see the hose is not kinked but nothing seems to work. Any ideas please?
    #487952
    is the tap symbol just on or flashing
    DIYer
    It is flashing quite rapidly and intermittently beeping
    #487954
    in that case its not a water fault
    from memory if its a steady light its water or drain
    if its flashing it can be anything else
    check the owners manual to confirm
    DIYer
    Thanks. The drain pump use to run even when the machine was off. I fixed that several times but I think the machine has probably given up after 7 years if this is a new error.
    #487956
    kaibart
    It’s a leak into the base of the dishwasher you need to dry the base run the dishwasher and identify where it’s leaking from
