Bosch dishwasher SPV40C10GB/40 FD9709 TAP light flashing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch dishwasher SPV40C10GB/40 FD9709 TAP light flashing
  • #103449
    dunston
    The dishwasher will not start. Nothing runs. Not filling. The TAP light flashes.
    No water in the base.
    Operating the anti flood float does not start the pump.
    We repair a lot of Bosch dishwashers but this is the first time we have seen this problem on this model.
    Th dw doesn’t have a display – wondering if this is indicating a E19 error (valve out let 11033896 fault)
    Any thoughts would be appreciated.
    #493184
    SteveATY
    Heat exchange valve open circuit?
    #493185
    SteveATY
    But I’m not sure it detects it that early in the cycle – you normally get the outlet pump running for a few seconds at the start of the cycle.
    It’s always trickier on non-display models as the tap symbol covers so many faults.
    I’d definitely take the right hand side panel off and check for any sign of a leak onto the control module.
    #493186
    yes agree look for module damage as its a quick easy thing to do
    the problem with this fault is all the flashing light means is I have a fault, no better than a check engine lamp
    can be all sorts of this right down to broken wires in the door
    I would check the heat exchange valve for continuity. if you happen to have a valve lying around swop the electrical connection and try it
    assume you have checked pump is not jammed as they can be very quiet if jammed completely
    dunston
    Thanks. We stock a heat exchanger valve. We’ll try a valve and check module for leak damage. Pump not jammed.
    #493188
    dunston
    This was a PCB fault.
