Bosch Dishwasher SRS43C22GB/04
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch Dishwasher SRS43C22GB/04
  • #50918
    Auldyn
    Bosh slimline dishwasher fills then pumps out some water typical over fill fault, problem is this model only has 1 microswitch above overfill float which incedently is working OK i.e no crud inside.
    When letting water in there is what appears to be a white solenoide valve at the bottom of the matrix where the fill pipe lets the water in it .
    I can not see a flow meter.. which would be my first suspision,and the machine has not leaked into the bottom tray.
    If it has a flow meter where is it on this model?
    when the machine eventualy fills the main wash pump starts OK with sufficient pressure but it continues to fill/empty in short cycles.
    has anyone any info on this model ?
    Paul
    Auldyn Electrics
    #306337
    gandh1
    lee8
    Re: Bosch Dishwasher SRS43C22GB/04
    Impellor Jug or flow meter is at the base of the water inlet tank next to the two drain hoses which enter the tank and exit the tank.
    BSH part no 607138
    #306339
    Auldyn
    Thanks gandh1 site down for maintainance at the moment
    #306340
    nomadPaul
    Auldyn , the ‘white solenoid valve’ that you saw on the bottom of the matrix is the impellor jug/flow rate meter that Lee8 is referring to.
    If this goes faulty or gets stuck , then you get the classic fill/drain/fill/drain cycle that you’ve stated is happening.
    You might also find the ‘Check water tap’ led is illuminated .
    #306341
    Auldyn
    Thanks spotted it now it looks like a small solenoide valve not the usual small “fan blower”shape.
