Re: Bosch Dishwasher Table Top
Take out the filter and look in the sump. There is a hole to the right that comes from the water metering system. Carefully rod out the pipe with a zip tie and then with a bottle brush (be careful not to push the blockage back up the pipe). Start the dishwasher up and the first few seconds of filling should push the muck out.
Failing that it’s body off, airbox off, metering system (round black chamber at the back right corner) off and the other end of the clear plastic hose from the sump is fitted there. Not difficult but fiddly and time consuming.
Hope that helps!
Steve.
