Bosch dishwasher tablet not disolving
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch dishwasher tablet not disolving
  • #31904
    trotter
    G’day all
    probably a silly question? I have a bosch dishwasher that is not disolving the detergent tab, customer first reported that the “Spring” wasn’t working.
    What she meant was the dispensor wasn’t throwing the tab into the cabinet!
    the dispensor is opening at the right time and I have cleaned both spray arms. I have seen both spray arms operating and thought all was well.
    Just got a call this morning to say that the tablet is still in the machine without having disolved.
    Am I missing something obvious? 😳
    #232857
    trotter
    Re: Bosch dishwasher tablet not disolving
    As a follow up…….I just thought that I would check the heater and that apears to be working 😮
    #232858
    senseib
    Has it got a short corrugated hose at the front, situated from left to centre in the base of the machine, this gets blocked up, resulting in not enough water 🙁
    HTH,
    Brian.
    #232859
    nomadPaul
    I know you said that you cleaned the spray arms and that they were working but did you see the top spray arm actually spinning ? I’ve had the odd occasion where i’ve thought i’d cleaned out the spray arm , only for a hidden ‘gem’ to get pushed back into one of the jets on first use .
    #232860
    petalpop
    get her to run it empty with a tablet just to check it ain`t something she is washing
    #232861
    trotter wrote:Am I missing something obvious?
    Yes mate…..the bl**dy model number?? 😉
    Mind reading is not an option here :rolls:
    #232862
    trotter
    Martin no mind reading? …..What sort of service engineer are you! 😆
    SGS56E02GB/35
    I have asked customer to test empty and she says same results. I definately saw top arm rotating – it showered me when I opened the door a little!
    Will have to check for that small hose Brian. Many thanks for all responses so far.
    #232863
    gegsy
    trotter wrote: Martin no mind reading? …..What sort of service engineer are you! 😆
    Why do you need to know Martins credentials??
    A model number isn’t asking for the world 😀
    FYI Martin has 30yr + to his credit if you must know 😀
    trotter
    now you have model number
    WHY IS MY TABLET NOT DISOLVING 😆
    And if martin got 30yr + then he must have done something REAL bad! 👿
    #232865
    gegsy
    Ok, most probable is that the water diverter on the heater assembly has failed and possibly taken the module with it. Depending on what sort of engineer you are, you will be able to deduce which, if both you require. 😕
    I’ve just reckoned it up you know? I started in the trade back in 1966 fixing small appliances, Hoover 119’s and Hoovermatics…..41 years ago…bl**dy hell!
    Nurse!…the screens please! 🙁
    #232867
    keithwilliams
    had these same symptoms last week. believe it or not, it was as simple as a lemon fresh thingy dangling in front of the soap box. moved it to back of basket and cured it. i wouldn’t have believed it, but it’s true.
    keith
    #232868
    craigieboy
    keithwilliams wrote:had these same symptoms last week. believe it or not, it was as simple as a lemon fresh thingy dangling in front of the soap box. moved it to back of basket and cured it. i wouldn’t have believed it, but it’s true.
    keith
    bsh enginneer hear first post watch for this fault guys have come across 3 of these recently all due to air freshener,also watch out for knive tray at top basket if not clipped exactley where it should be can cause door and leaking problems
    #232869
    Welcome to the nut house, Craig, enjoy. There’s a few of your compatriots in here as well 😀 .
