Bosch dishwasher Tap Symbol stays on doesn’t continue with cycle
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch dishwasher Tap Symbol stays on doesn’t continue with cycle
  • #101806
    cleanmedishes
    Model Number SGV46M03GB/36 Brand Bosch Age More than 10 years Hi,
    Last night switched on dishwasher when checked it this morning the cycle was stuck on 42 mins left with a tap symbol on next to the time
    I have tried the following things so far:
    Checked and cleaned the filter – it was clean anyway
    Checked water pressure from inlet – seems fine to me
    Checked pipes for kinks etc – all seem good
    Removed filter on the inlet (the small one) and cleaned it
    Symptoms are if I cancel the tap symbol by resting the cycle and start a new cycle any water already in the dishwasher is drained out, i have double checked this by putting the outlet into a bucket and making sure water is getting through. However once the machine is drained and the new cycle starts it just keeps getting more and more water into the dishwasher but it doesn’t drain any of it . If i reset and do it again , once again all the water already in the dishwasher is drained but it then stops draining and the tap symbol comes on and the cycle doesn’t carry on it gets stuck on 18 mins or 147 mins whatever the full length of the cycle is
    I remember the dishwasher we had before this one did the same thing and back then i couldn’t work out what was wrong with it either. Not sure what the issue is , none of the pipes have been touched etc
    Any help would be appreciated not sure if its time for a new dishwasher but if i can save some money then all the better.
    Thank you
    #486240
    very likely this is at fault
    https://shop.ukwhitegoods.co.uk/424099-bosch-dishwasher-flow-meter
    had this a few times but cant promise to cure it
    cleanmedishes
    Ok thank you for the quick response
    I will have to find how to replace it first but it doesn’t seem like a big job
    #486242
    cleanmedishes
    Ok i had a look and its easy replacement so will be ordering that part
    One more thing both the ropes on the door hinges are snapped , but i cant find the correct rope (with correct model number) on the site , can you advise which one would work if any ?
    I didn’t want to start a new thread 🙂
    #486243
