bosch dishwasher timer
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts bosch dishwasher timer
  • #35678
    suedehead1
    hi,
    i called oout to look at this dishwasher today the timer will not move on anywhere, unfortunately the label with the model number on it has been removed.
    the timer says EC4890.01A on it, EMW dont do it.
    does anyone know what the bosch part number for this timer is please or tell me where else on the machine the model number would be i have looked under the lid down the back all round the edges of the door, underneath no joy.
    thanks.
    #247578
    Re: bosch dishwasher timer
    It is often engraved along the top inner edge of the door, very difficult to see sometimes, you just have to get it at the right angle.
    suedehead1
    its pre engraved door type i checked but thanks for the reply
    #247580
    No – all “pre-engraved” timers were AKO. Engraved doors came in with the plastic base, as did the Eaton timer – the common one was the EC4750. Given that your timer has a higher number, it must be later. I can find no reference to it anywhere. The very late machines have a white plastic label down the right hand edge of the door; if it isn’t there, you’re in trouble if the customer has no purchase records.
    suedehead1 wrote:hi,
    Sounds like the timer motor drive cog has slipped down the shaft then? Tapping it back on could sort it or simply change the motor, no need for a timer in that case. 😉
