Bosch dishwasher wax motor test
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch dishwasher wax motor test
  • #86763
    Ljs007
    I have a Bosch dishwasher which has developed a fault where the detergent dispenser does not open during any of the cycles. I’ve narrowed down the fault to either the wax motor or the feed into the motor.
    I’d like to test the electrical feed coming from the connector into the wax motor and also if possible manually activate the wax motor. I have a multimeter but am unsure how to run any of these tests.
    Any help much appreciated
    #432962
    Re: Bosch dishwasher wax motor test
    Replace it without bothering to test it. They are notorious for blowing the main circuit board when they fail so you’d best check the main circuit board too while you’re at it!
    #432963
    Ljs007
    I replaced the wax motor but it hasn’t made any difference unfortunately. If the main circuit board had gone too would I be able to tell?
    The dishwasher is working fine all except the wax motor isn’t opening the dispenser door.
    #432964
    What of the latch on the dispenser door, does that operate correctly if you were to simulate the wax motor’s action?
