Bosch dishwashers
  • #31692
    ChrisR
    Hi guys.
    I`ve had two this week which stop with one minute to run and will not switch off unless the reset is activated but neither do it all the time.
    I`ve changed the pressure chamber on one for for a underfilling problem but not done anything to the other.
    I`ve checked both for water in the base but both are dry and the anti-flood is not activated.
    Any ideas?
    Thanks.
    gegsy
    Re: Bosch dishwashers
    Is there any crud in the water matrix around the breather area (top right)
    ChrisR wrote:Any ideas?
    Eh Chris! You know the rules, model no’s are best 😉
    Those m/c’s with heat exchangers behave differently after all…. 😉
    #232111
    ChrisR
    To be honest Greg,I don`t know. I have`nt checked there.
    #232112
    ChrisR
    Sorry Martin.
    SGV56A03GB/42 and SG556E02GB/35.
    #232113
    gegsy
    Crud in the matrix and pressure chamber and that ribbed transfer pipe will cause your fault.
    Martin, you are up late mate 😀
    ChrisR
    I cleaned the one out about three weeks ago before fitting the new pressure chamber.
    The other one has been cleaned but over a year ago.
    #232115
    gegsy wrote:Martin, you are up late mate 😀
    I was last night wasn’t I?
    Fact is my daughter was holding a Virgin Vie party….oh yes……the house was full of crumpet….(all too much for me)…..so I hid in my little hovel watching the Everton match (great match by the way) and working a bit of UKW…. :rolls:
    Hey Ho!
