I have a dishwasher where the cycle takes up to 3 hours. the machine is 5 years old. My wife says it could be the thermostat. Any ideas what could be wrong? thank you.
A model would be hepful jimbo as there are many variants.
If your appliance has an “auto” setting and you are not cleaning the plates off before you load; making the water very murky then the turbidity system will adjust the wash accordingly, although 3 hours does seem excessive.
Poss model SGS5312GB/07/12/13 as your model doesnt exist.
More than likely if it is that model it is our old favourite burnt track on heater relay in fascia pcb.
This is solderable if you are confident, failing that you will need to replace the full pcb. P/no 264877 – £83.00 GBP from Bosch but check spares@ first.
as always unplug before attempting any repair :plug:
