Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch DKE995AGB hood – no lights!!
- This topic has 6 replies, 3 voices, and was last updated 18 years, 7 months ago by
aqualectric.
August 28, 2007 at 8:38 pm #30107
aqualectric
ParticipantBosch DKE995AGB cooker hood. FD. 8007.
This damn thing has raised it’s ugly head again!! 👿
The lamps (12V) either side do not work. Bulbs have continuity. Traced the supply wiring back to the transformer – no mains voltage into it. The supply cable from the transformer comes from the PCB edge connector. I am assuming it’s a board fault. But with the exorbitant price tag, I’ve got to be sure. All the fan motor selections work fine. Customer says that sometimes the hood just hums when the fan is switched on – capacitor looks OK, and the unit worked fine for me. Could the PCB cause this too??
When the ‘lamp’ button is pressed, the PCB buzzer sounds; so I’m thinking that the switch panel functions OK. 😕
Also there is what I assume to be a sensor connected in-line with the lamps. This must be the ‘filter blocked’ check sensor – am I right??Any ideas on this please!!!!
Steve.
August 29, 2007 at 7:42 pm #225935aqualectric
ParticipantRe: Bosch DKE995AGB hood – no lights!!
Any ideas??? 😕
Cheers,
Steve.
September 3, 2007 at 9:03 am #225936aqualectric
Any help appreciated!! 🙂
Steve.
September 16, 2007 at 8:34 pm #225937Beever
4.0A Fuse on pcb part no:- 705194
September 18, 2007 at 7:00 pm #225938aqualectric
I found the fuse and it tested out OK. 😕 So I am assuming it’s the PCB at fault. There is no power supply to the lamp transformer and the fan sometimes hums when switched off.
Weird thing – and a joy to dismantle – NOT!!! Brand new induction hob directly beneath….gulp!!!Thanks for the input. If you can help some more, it would be greatly appreciated.
Steve.
September 18, 2007 at 8:12 pm #225939superfix
aqualectric wrote:I found the fuse and it tested out OK. 😕 So I am assuming it’s the PCB at fault. There is no power supply to the lamp transformer and the fan sometimes hums when switched off.
Steve.
Have know the pcb 264223 supply low voltage to motor in the past. Not cheap to replace though :rolls: .
September 18, 2007 at 11:33 pm #225940aqualectric
I know – :rolls: – the customer is still recovering from the shock!! At that price and also being a non – returnable part, I need to be sure otherwise I’d rather turn the job down.
Thanks,
Steve.
