Re: Bosch door not shutting properly- Please can you help?
Faulty hinges will prevent the door shutting properly and this will cause high temp and motor running constantly as the unit tries to cool itself.. this in turn will create loads of condensation.
Effectively, you should replace any faulty hinges to remedy.. another way to look at it is that if the problem isnt remedied soon then the cost of the excess electricity could soon mount to the cost of the replacement hinges.
