Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › bosch double oven
- This topic has 9 replies, 4 voices, and was last updated 5 years, 7 months ago by
suedehead1.
August 18, 2020 at 6:57 am #98195
suedehead1
ParticipantHBN9151GB/06. the main oven only heats to about 180 degrees I fitted a new element and thermostat and it is still the same,
the fan is going . any ideas welcomedAugust 18, 2020 at 8:26 am #471318electrofix
Moderatoryou say it heats to 180 and stops How ?
does the stat switch off ?
does the stat and motor switch off ?its a simple system so cant be a lot
how are you measuring the temp and what have you got it set to ie 200 220 ?
August 18, 2020 at 2:59 pm #471319wilf
Participanthave you checked the knob is fully operating the stat i.e the actual temprature against the set temprature.
wilf
August 18, 2020 at 7:43 pm #471320suedehead1
ParticipantHi,
I move the knob to 100 then 150 light goes off i turn it to about 180 it never gets that hot . I can see the element glowing red but beforeit gets to 180 the element goes off the fan motor keeps running and it starts to cool down the knobgoes onto a switch which turns the stat all operatingok.August 18, 2020 at 8:23 pm #471321electrofix
Moderatori assume the sensor is in the correct position and the correct stat is fitted 00489378
if your using an oven temperature guage put is as close to the sensor as you can get it and see what you get
August 19, 2020 at 6:15 am #471322suedehead1
Participanthi, yes fitted genuine stat oven thermostat and genuine element right next to sensor
August 19, 2020 at 8:05 am #471323electrofix
Moderatorwell i cant figure anything that you have got wrong
unless its a faulty stat then a bit out of ideas now
August 19, 2020 at 12:51 pm #471324Hollytree_Technical
ParticipantIt looks like it has 2 cooling fans – are either/both running (especially the one located between the 2 ovens)? If not it could be tripping the chassis overheat cut out on the back of the oven.
Jem
August 19, 2020 at 8:09 pm #471325suedehead1
Participantok thanks I will get another look
August 23, 2020 at 9:29 am #471326suedehead1
Participantwent out for another look there is a small cut out thermostat above the fan motor which looks like a one shot thermostat which cuts out about 180 ,but somehow
cuts back in I bypassed it to tryand it worked perfectly, new cut out ordered thanks for the help with this one, -
