Bosch Double oven HBN56M551B/10 fan motor issue
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch Double oven HBN56M551B/10 fan motor issue
  • #94751
    asp11
    Hello all – The main oven Fan motor won’t run…. all the elements are fine and work but there’s No power going to the fan motor.
    I’ve checked the motir & wires, selector switch, ceramic block and button stat above it and all appear alright.
    Is this a control board fault (which is obsolete) OR is there something I’ve missed?
    Any help would be great. Thank you
    #458222
    Mo3426
    connect are showing one board in stock but limited stock is it possible to run a feed from the selector switch
    #458223
    asp11
    Not sure I’d be sure enough to connect the right wires…. So you also think its a board failure then?
    #458224
    if the fan is controlled by a relay on the board could be a simple relay failure
    asp11
    Thanks for your help Dave
