Bosch double oven HNN455BGB/01 – no power to lower oven?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Bosch double oven HNN455BGB/01 – no power to lower oven?
  • #57712
    itiejim
    Today I went to turn the lower oven of my Bosh double oven on to find that it won’t work – the fan, oven element and grill element are all refusing to do anything. The top one and clock etc are fine.
    I see that there is just one switch to power the whole unit but didn’t know if there are separate fuses / trips inside that might be causing problems? The only reason I can think that this might have occurred is that the electricity board cut off the mains power today and then switched it back on again. Perhaps a power spike tripped something?
    Any help would be most appreciated!
    #332050
    gandh1
    Re: Bosch double oven – no power to lower oven?
    i think you mean HBN455BGB/01
    correct???
    unless selector has gone up the creek, it does sound like maybe child lock is on or auto-cook mode has been selected though…
    #332051
    itiejim
    Re: Bosch double oven HNN455BGB/01 – no power to lower oven?
    Indeed – HBN455BGB/01 – thanks!
    I wasn’t aware there was a child safety mode to be honest – any ideas how I would de-activate it? I’ll have to try to find the instructions re the auto cook mode as I’ve never used it…
    As for the selector, any idea how I’d test / eliminate it to find out if it’s the problem?
    Thanks for the reply 😀
    #332052
    nomadPaul
    Have you set the clock ? The main oven won’t work unless the clock is set and not flashing digits
