Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Bosch Double Oven MBS533BS0B Tripping MRB
- This topic has 11 replies, 2 voices, and was last updated 4 years, 9 months ago by
mvteng.
June 28, 2021 at 1:12 pm #99729
mvteng
ParticipantBosch Double Oven MBS533BS0B – when using both ovens occasionally it will trip the MRB. Not often, maybe once a month.
The MRB is 16A (Type CUMB16)
The Bosch Data Sheet for the over shows current 32A
Is this just a simple case of the MRB being too small for that particular oven?
June 28, 2021 at 8:57 pm #477644electrofix
Moderator16a is too low but before uprating breaker make sure the cable is able to take the extra load
June 29, 2021 at 8:03 am #477645mvteng
ParticipantPerfect Dave. Thanks. Cable is 6mm2 so should be good i think
June 29, 2021 at 8:26 am #477646electrofix
Moderatorno probs with that just uprate to 32A
June 29, 2021 at 8:30 am #477647mvteng
ParticipantThanks again Dave
July 7, 2021 at 5:16 pm #477648mvteng
ParticipantMRB uprated to 32A. been fine for a few days, but now when top grill is switched on it trips the RCD after about 2 minutes.
It doesnt trip straightaway, but pretty much trips everytime on the grill after its been on for a couple of minutes.
reset the RCD and its fine, it doesnt trip again.
Any ideas?
July 7, 2021 at 7:43 pm #477649electrofix
Moderatordoes it only trip on the grill setting ?
most of the time this type of fault is an element with a slight earth fault
July 8, 2021 at 8:30 am #477650mvteng
ParticipantThanks Dave
I think its only the grill setting. I need to keep checking.
when you say a slight earth fault – is that a loose connection? or is that normally a fault in the element itself?
It switches on for a couple of minutes before it trips, so I wondered if it was some sort of thermostat issue i.e. when it gets to a certain temperature???
After reset, the grill heats up with no issue. Strange
July 8, 2021 at 8:33 am #477651electrofix
Moderatorno one of the elements is faulty
had the identical fault on a creda last week. grill heated for 10 mins then blew trip, changed element now ok
July 8, 2021 at 2:45 pm #477652mvteng
Participantok. Thanks Dave.
Element is fine after the RCD is reset.
switch on grill
wait 2 minutes – RCD trips
reset RCD
Grill fine after that. I can see its bright orange all around
If the element is faulty , would this happen? would it not just keep tripping the RCD?
Sorry – just trying to understand
July 8, 2021 at 11:39 pm #477653electrofix
Moderatorits a hard one when the fault does not repeat
I cant say 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} thats its the element but its more then liklely.
to be certain you would have to test the element insulation resistance just after it trips
August 12, 2021 at 5:38 pm #477654mvteng
ParticipantSo – Good news and bad news
On inspection the 2 grill elements look identical. Same shape, same connections, so I simply swapped them over to find out if the fault was the element.
Good news – the new top grill (old bottom grill element) no longer trips the RCD.
Bad news – The small fan behind the grill is now constantly on. This is not the big fan in the main oven – this is the one that circulates air around both ovens (cooling fan?) Normally it switches off after the oven has cooled down . Cant see any loose wires that I might have dislodged, and the procedure to swap the grill element was really straightforward
Any ideas
