Bosch Draining Issue
  • #96714
    ian07
    Hi, I have a Bosch Exxcl 7 that comes up with error code E18.
    I have followed Bosch’s online help, take out trap at front etc but I still have an intermittent draining problem.
    I have even looked to see if the impella is spinning on drain (it is)
    I have just tried it on a 15 min wash & came up E18, tried the Drain programme a few times & its drained fine.
    Any ideas?
    Cheers for any help
    Ian
    #464548
    but does it drain quick enough ?
    ian07
    electrofix wrote:but does it drain quick enough ?
    When it does actually drain it seems fine, when its not it sounds like a muted grumble/moan (hard to describe)
    Cheers
    Ian
    #464550
    you can get intermittent drain problem with blockages. I have had coins up hoses where they act like a valve depending on their orientation. if the hose has been extended check where it joins
    if the groan you describe comes from the pump may be a worn bearing
    how old is it ?
    ian07
    I’ll check the drain hose tonight when I get in.
    I think it’s about 8-9yrs old
    Thanks again
    Ian
    #464552
    ian07
    OK I think the pump (bearings) might have gone. I’ve checked the drain hose & all seems OK.
    I’ve un done it from the waste pipe & put it in a large saucepan,while in the pan it empties really well, but if i left it up (to worktop height) then it struggles & not much happens (apert from a noise that sounds like its struggling)
    I could record a quick video it thats needed.
    Cheers
    Ian
    #464553
    could easily be
    what is the full Enr number ?
    ian07
    electrofix wrote:could easily be
    Its : WAQ24460GB/01. FD9103 00044
    Cheers
    Ian
    #464555
    compatible pump
    https://shop.ukwhitegoods.co.uk/pmp271-compatible-washing-machine-drain-pump £25.96 + p&p from site
    gen pump is cheaper direct from bosch gen part no 145212 bosch price £56.68 not sure about postage
    https://www.bosch-home.co.uk/customer-service/care-protection-and-parts/spare-parts
    from numbers machine made march 2011
    bammec
    electrofix wrote:gen pump is cheaper direct from bosch gen part no 145212 bosch price £56.68 not sure about postage
    For orders under £9.99, delivery is £2.99. For orders between £10.00 to £29.99, delivery is £4.95. For orders over £30, delivery is free. For orders which include a small appliance, delivery is free.
    I believe the quote in bold applies. Taken from here: https://www.bosch-home.co.uk/store/00145212
    #464557
    ian07
    Thank you all for your help, I’ll let you know how I get on.
    Regards
    Ian
