bosch dryer 3204gb
  • #11927
    Bosch Tumble dryer 3204gb/09
    dryer starts up in a clockwise direction and heater relay engages
    dryer stops to reverse and starts going in anti clok direction but heater relay does not engage
    when dryer stops again to go clockwise heater relay engages (somtimes)
    have checked exhaust thermistor and am getting around 11k tried a 5k6 resistor in place of and got no difference
    if i disconnect thermistor i get a flashing iron dry light another one for your fault codes list
    anyone any ideas on this one even put wet clothes in it to see if it made difference but no
    any ideas would be good
    thanks Dave
    #147203
    Simon46
    Re: bosch dryer 3204gb
    Is this the one with the carbon brush which wears out on the drum?
    #147204
    yes it is the one with the carbon brush have held brush in contact and does not seem to change problem
    there is a setting for a 30 min cycle since this is timed i would not expect the sensors to be active but i may be wrong
    Please give us the correct model number, it really would help 😉
    #147206
    Simon46
    Does it work o.k on 30 minute cycle?
    S.
    #147207
    …by the way, because the fan only blows air in one direction only and thru the element box, during the short 3 second reverse tumble its not blowing and so the element switches off to prevent overheating !
    #147208
    superfix
    Depending on model,m/c does not pull full current for at least 5 mins.As comparison is made between ntc’s.If you disconnect one then it will show fault.
    Have you checked carbon pick up on rear bearing?
    HTH
    #147209
    sorry had not noticed i had not put letters in model no will post tomorrow when i have checked cant remember them
    @ simon46 no it does not work any better on 30 cycle
    will take off element cover and check for a carbon pickup
    there were one or two times when the element came back on for a second time but then failed later. its like the board is being told to keep element off through a faulty sensor or the like
    thanks for all help so far
    full model no WTA 3204 gb 09
    sorry for omission
    #147211
    clivejameson
    Did you get a fix for this one electrofix? I’ve got the identical model (WTA3204/GB09 Fd 8306) with exactly the same problem namely it only powers the heater in the anticlock direction and the drum brush contacts appear healthy.
    If anyone else has come across this i’d be pleased to know the outcome.
    #147212
    clivejameson
    Anyone?
    #147213
    never really got an answer to this one dryer seemed to right itself but has now been scrapped by customer as the heater failed still have dryer looking for s/h heater or will try to fix original if i get time
