Bosch Dryer Error ?
  • #5162
    Dave_Conway
    Does anyone have any idea what could be causing this ?
    Bosch WTL6102GB/02 Condenser dryer.
    After two minutes or so the dryer cuts out and two lights are on:
    Start/Stop light on permanently
    Cupboard dry light flashing
    Thanks in advance
    #109314
    Re: Bosch Dryer Error ?
    The fault almost certainly is caused by a blocked pump hose to the condensor reservoir. Take the LH side panel off to access the small black hose and clear the blockage. (Usually caused by the customer not cleaning the condensor matrix and fluff filter regularly)
    Dave_Conway
    Thanks Martin. 😀
    I will pass it on to the engineer.
    #109316
    sparkey
    Flashing cupboard dry light indicates overheat condition, Tech info suggests “checking air route and pollen filter” ?? personally I would carefully check condensor matrix, washing out in all directions with garden hose
    #109317
    Instruction booklets are a guide designed only to confuse the reader.
