Bosch dryer not collecting water
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Bosch dryer not collecting water
  • #70067
    shintyboy1
    I have a Bosch WTE6920GB/04 condenser/dryer. It is heating as normal but not collecting the water in the compartment. I have cleaned the entire machine,cleared the water runway from the condenser and cleared the filter and condenser.I have discovered that the pump stops working after approx 30 seconds when started. I have replaced the pump. There is also a float switch which can cut off the pump when the water level rises but I have replaced it also. I have also renewed the capacitor but still the same problem. Anyone any ideas?
    #376910
    Re: Bosch dryer not collecting water
    shintyboy1 wrote:There is also a float switch which can cut off the pump when the water level rises but I have replaced it also.
    Hold up :hmm: When the water level in the float chamber rises the pump should turn ON and not the other way around. 😕 The pump then drains the water up to the water container, the level in the float chamber falls and the pump switches off…!
    #376911
    shintyboy1
    Ah,OK that explains that! Any ideas why there is no water collecting in the tank? I have tried running the machine with the float switch “pressed” but it still cuts out after approx 30 seconds?
    #376912
    alyp
    hello
    we have the same problem – did you manage to fix it ?
