Bosch dryer showing filter light
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch dryer showing filter light
  • #96701
    pmb
    Hi I am stuck on a WTW863S1GB/17 heatpump dryer which is showing the filter needs cleaning even though it’s spotless. I assume it is blocked in the area where a condenser normally is. I notice you can’t order that part on the Bosch site, but it shows it separate from the base. Can I remove it to clean without causing a problem? Is there anywhere else it could be blocked?
    I ordered a new front drum seal as tons of fluff has filled the inside up.
    Thanks, Darren
    #464490
    not got much info on this unit the closest I can find is
    https://www.manualslib.com/manual/1429541/Bosch-Wtw86560au.html
    its an Australian model but prob has similarities
    pmb
    Thanks a lot Dave
