BOSCH DRYER wta4007gb/04
  • #38049
    HI
    went to this yesterday and the belts gone,needed to order one up
    £26.37…..?,regards fitting,never taken one of these apart yet.
    looks like an front cover off job, and over the drum on to some pully wheels, ……..? ,is that it, or are there any tips on this one
    best regards to all.
    canufixit
    #257518
    gegsy
    Re: BOSH DRYER wta4007gb/04
    Belt removal
    Take of the opening cover on the base plate.
    Remove the belt from the belt tension adjuster.
    Take off work top panel, facia panel, front panel and bearing. (see dismantling bearing plate.)
    Belt Tension adjuster
    Put the appliance on its back.
    Open the opening ion the base plate.
    Take off the belt.
    Remove the two screws of the belt tension adjuster at the base plate and take off belt tension adjusters over the opening in the base plate
    Belt mounting
    To put new one on you need to draw up the belt over the drum
    Hang up and bolt bearing plate and then stretch the belt with the belt tension adjuster (if you have one 😉 )
    Close the opening on the base and re assmble fascia etc.
    HTH
    Re: BOSCH DRYER wta4007gb/04
    hi Greg
    manythanks for that info. 😀
    regards
    canufixit
