Bosch dryer WTA74200GB/07
  • #100820
    SWERV
    this vented dryer stops intermittently with the filter light on and won’t restart.
    It has been fully stripped down and cleaned out, no blockages or air restrictions. I am sure I read somewhere about the NTC that could cause this. The measurements checked out ok, but I did replace it and still the same fault.
    The only thing I can think of, is the control board. Does anyone else have any thoughts?.
    Merv
    #482305
    have you had a good look at the element. sometimes the element coils can sag and cause a hot spot
    SWERV
    Hi Dave,
    yes, I did have a good look at the element and it looked in good shape.
    Merv
    #482307
    was trying to think how it would sense filter blocked and since there only seems to be one thermistor (and you have swopped it) I cant think of anything else. Was thinking condensor at first but this is vented so all the usual problems go out the window. I assume its got access to lots of cold air as i am looking for a way the heater would give a raised temp
    assume from what you say you have checked all filters and air flow to outside. As a long shot have you removed and replaced wiring plugs on the pcb ?
    SWERV
    Hi Dave,
    yes I have checked the filters. The vent hose is spotless and it hangs straight out of the window which is behind the dryer.
    I didn’t remove the board or check the connections, so I suppose that is a possibility.
    Merv
    #482309
    also dont forget some dryers out there wont turn on heater till they detect moisture
