Hi, I’ve not come across this model before. Just over two years old.
The machine isn’t drying fully.
e.g. set to cottons dry with wet towels in. Initially shows around 2hrs30mins. Heater activated, (although not as hot as I think it should be), good air flow. after about 10 minutes the display drops to zero and finishes.
The only ntc is mounted on the heater as is usual but it doesn’t have a humidity sensor at the front like previous Bosch versions.
Any ideas?
