Bosch dryer WTA79200GB/04
  • #103465
    suedehead1
    Hi the dryer runs for a couple of minutes, heats and turns then goes to end with the clothes still wet, I replaced the sensor/ntc on the element
    but its made no difference. its vented no blockages, any ideas welcomed
    #493275
    have you cleaned the moisture detector inside ?
    if it has a timed programme does that run ?
    simonb
    Like Dave says, give the Electrode a good wipe, for the cost we usually send an engineer with a new electrode part number 10000304 less than £10
    #493277
    suedehead1
    I didnt know there was an electrode i will give it a try thanks guys
    #493278
    will be a metal strip just inside the door at the front
