Bosch Dryer WTL6300GB/01
  • #55691
    scots
    Anyone got info on this model.
    I have this one which only seems to switch on the 600w element the other being 1600w.
    It doesn’t matter if you set to cotton dry or delicates.
    Any help appreciated.
    Brian
    #324778
    Re: Bosch Dryer WTL6300GB/01
    I seem to recall some info on dryers that said
    lower power element was switched on first and if wet clothes were detected it switched on the second element
    i would try it on a timed programme or make sure enough damp clothes where inside also check if cust been using bounce (or similar) as this coates the sensors an play havoc
    hope this helps
    DAve
    #324779
    scots
    Cheers Dave.
    I have tried on timed although on these dryers the timed is a 20m gentle heat, not sure why but hey I didn’t design em.
    Will try contact Bosch and see if they can give me any tech info on these dryers.
    Thanks for reply
    Brian
