Bosch Dryers Fault Codes
  • #17504
    R055
    Hi guys,
    Does anyone know any of the BOSCH fault codes? Cup-board dry light flashes…any ideas?
    #174628
    Re: Bosch Dryers Fault Codes
    R055 wrote:Cup-board dry light flashes…any ideas?
    Sure! (but next time it would really be helpful if you give us the full ENR number of the Bosch machine in question 😉 )
    Likely as not the pump to water container hose is blocked with something? And the channel behind the condenser box is flooded? Take the hose couplings off and flush clear! Probably a mass of fluff and crud where the customer doesn’t take care to clean the machine out after use?
