Bosch DW detergent dispenser problem
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch DW detergent dispenser problem
  • #54605
    Jumty
    We have a slimline Bosch DW – model number unknown – but it is about 10 years old and has given excellent service.
    We’re having a problem with the door on the detergent dispenser. The spring release mechanism is no longer holding it in place until the correct part of the wash cycle.
    Will this be an easy problem to resolve?
    #320305
    don
    Re: Bosch DW detergent dispenser problem
    Hi jumty
    Without a model number or as it`s known on Bosch appliances an enr no. it`s an impossible task i`m afraid. ENR no. can be found either along the top metal edge of the door just left of centre stamped into the metal or on a label on one of the upright door edges.
    Original reciept or instruction booklet may reveal the info if you still have them.
    HTH 🙂
    Don
    #320306
    Jumty
    It’s an SRS4302GB/02.
    #320307
    nomadPaul
    The part number for the full dispenser is 490467 and retails at about £43+ V.A.T
    It may be possible to just replace the lid and spring but this is not always successful.
    #320308
    Jumty
    Is replacing the dispenser a straightforward task?
    #320309
    Deadly….. Power and door outer off, bend back the lethally sharp locking tongues to release the old dispenser, bend them back down, then force the new dispenser into place.
    You will cut yourself.
    Jumty
    Thanks for the info.
    #320311
    Jumty
    What a pallaver and unbelievably crude. I’m not convinced that the seal will be watertight.
    Engineered by the Fray Bentos company :rolls:
