Bosch dw door seal
  • #57469
    pmb
    Hi i went to a Bosch dw today with no enr number on it, i looked everywhere and cleaned the stainless steel to try to find it but there’s nothing. It was the type where the lower part of the tub inside the door is plastic and there is a base panel that can be taken off for easy access to motor, pump and heater. I need to order a door seal for it can anyone tell me an enr for one of these or part number, i really hope that type only has one door seal.
    Thanks Peter 🙂
    #331156
    BobHope
    Re: Bosch dw door seal
    the numbers are etched into the top of the door in the centre, you need to be at the right angle to see them correctly.
    Bob.
    #331157
    pmb
    Hi Bob thanks they normally are but this one didn’t have anything etched onto it, i cleaned the whole door up, shone a bright torch onto it and spent ages carefully checking the whole area, there is definitely nothing on there. I am really stuck because there is no number on there anywhere, i have tried searching Bosch dw door seals on connect and putting the enr numbers into the Bosch site and seeing if any are for this type of machine but no joy 🙁 any help on this would be really great
    #331158
    nomadPaul
    I think its 298534…..if you’re talking about the lower edge door seal as opposed to the one that runs round the front of the tub.
    #331159
    pmb
    Thats the one, thanks alot Paul, that has really helped me out alot 😀
