bosch dw enr sgs43t62gb/74
  • #63261
    AASWALES
    Hi the above dishwasher has the check water light coming on at irregular times , when i got there i put in on wash the machine pumped stopped pumped again filled 2 sec stopped filled and wash pump then pumped out and the check water light came on .
    i then started a different wash and it just pumped out the the check water light came on very quickly
    any ideas ???
    cheers Alan
    #353211
    Re: bosch dw enr sgs43t62gb/74
    AASWALES wrote:any ideas ???
    Duff Impellor Jug (Pt No: 424099) I expect! 😉
    #353212
    AASWALES
    ok thanks for your your reply ill take a look
    cheers
    #353213
    AASWALES
    hi i fitted the jug but the problem is still there !
    when i fitted the jug it filled and started to wash for about 10 mins so i reset and went on to the next call thinking it was fixed but the customer rang she said the water light came on again after about 15 mins ???
    Im thinking pcb ???
    any ideas
    cheers alan
    #353214
    I hope you fitted it the right way round? (There’s an arrow symbol on the meter indicating flow direction). 😉
    #353215
    AASWALES
    yes i noticed that , its on the right way ,
    alan
    #353216
    AASWALES wrote:yes i noticed that , its on the right way ,
    In that case the symptoms may now have changed? The ‘check water’ LED can come on due to a number of different faults (i.e, blocked pump, transfer tube etc). Have you been back to look at it?
    #353217
    AASWALES
    yes i cannot find any blockages it washes perfectly for about 10 – 15 mins then light on , pump is good all pipes clear d/w is very clean i dont think its used much !!
    the symptoms have changes since i put the jug on it now takes longer for the light to come on ?
    thanks for your help Martin
    Alan
