bosch DW sgs43a18gb/38 lower spray arm
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bosch DW sgs43a18gb/38 lower spray arm
  • #17743
    maltheviking
    Help please
    I have one of these that the lower spray arm does not revolve. No apparent wear, I can hear the spray arm motor/diverter valve running when first switching on but no water circulating through lower arm. I suspect a blockage.
    #176146
    maltheviking
    Re: bosch DW sgs43a18gb/38 lower spray arm
    Update. 😉
    Not a blockage, turned out to be the diverter valve, disk inside heater box has sheared off, looks as if the spindle that it is mounted on has crumbled away.
    Anyone know if this is a common fault or is there a known reason for this to happen? 🙂
    #176147
    gegsy
    Or insufficient water level 😉
    Check for the usual with these……GUNGE
    483058 – heater/diverter valve assembly – £72.85 list
    maltheviking
    Thanks my feathered friend. 🙂 one on order.
