Bosch DW SGS43A42UK/01 FD 820900849 prog sticks
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch DW SGS43A42UK/01 FD 820900849 prog sticks
  • #80178
    Bernie
    Bosch SGS43A42UK/01 FD 820900849 prog sticks
    This is on the quick wash:-
    The machine fills washes and heats all ok, drains, then fills and washes, middle led is on “Active” and that is where it stays did open and close the door, machine then started to heat for drying cycle and goes right through to the end, end led on.
    This is exactly what happens when the customer uses it, sticks on “Active” just keeps washing.
    Any help much appreciate
    Bernie
    #412000
    Re: Bosch DW SGS43A42UK/01 FD 820900849 prog sticks
    It could be something simple like the magnet float sticking under the sieve or the drain pump a little tired due to old age?
    #412001
    Bernie
    Thanks Martin for the very quick reply, not sure about the drain pump, as it drains ok just does not appear to heat for drying.
    #412002
    Bernie wrote:it drains ok just does not appear to heat for drying.
    Time to look for burnt relay pin on the PCB then. 😉
