bosch dw SHV55M03GB/40
  • #72778
    johno1998
    Hi have problem with lower spray arm not turning. Done all the normal checks.There is enough water in it, water is heating,top spray arm is turning,So have changed main wash pump but still the same Could this be water diverter in the heater and can i get just diverter or is it heater job,.
    #385521
    RocketMan
    Re: bosch dw SHV55M03GB/40
    Diverter is not available as a seperate item. Part no 488856 for combined heater/diverter unit.
    It sound like it could be a diverter problem.
    #385522
    johno1998
    Hi thanks for the response so is it a heater out job or is it easier to take diverter of the old heater unit and replace with diverter of the new heater unit.?
    #385523
    johno1998 wrote:Hi thanks for the response so is it a heater out job or is it easier to take diverter of the old heater unit and replace with diverter of the new heater unit.?
    Don’t even think of doing that unless you want to create more problems for yourself. 😐
    Common reasons the diverter valve (or water point in Bosch speak) failing are: cam plate jams in heater unit as the heater unit plastic warps. Main drive shaft water seal leaks onto drive motor and finally the gears tend to jam. That’s not to say you can’t swap it over if you wish, you are free to make that choice. 😈
    #385524
    johno1998
    Ok thanks Martin I will just change the heater unit cheers.
    #385525
    Bernie
    Just a thought have you tried a diagnostic reset – holding normal and eco buttons while switching on.
    I have just had a problem with a Bosh DW and I think it was a fault with the diverter valve stuck and this did the trick
    Bernie
    #385526
    johno1998
    thanks Bernie i havent tried that will let you know how i get on
    #385527
    Bernie wrote:Just a thought have you tried a diagnostic reset – holding normal and eco buttons while switching on.
    Bernie
    Bernie I hate to tell you this but resetting the programme has no effect whatsoever on the operation of the diverter in the heater box. There is not cure for a sticking diverter valve other than to replace the complete instantaneous heater unit. 😉
