On any setting this machine will start to fill as normal then within approx 30secs will pump out, go to 1min and show error E14 (sometimes E18) I have checked the air break and there are no leaks in the base. I found out that this fault maybe the reed switch senser which I think is a small plastic item with a pcb inside it…. but I’ve changed it and the fault is still present.
The appliance does a little more now, it washes for a few secs then pumps out and now still goes to 1min and shows E14
Any ideas please?
