Bosch Dw SRS 56A02GB/B
Viewing 15 posts - 1 through 15 (of 27 total)
  • #17613
    Lawrence
    cust complaint poor wash results,specifically rear left cornr of top rack,when it starts to wash there is a distinct hum and then it only pushes water through the bottom spray arm is there a diverter valve or something that could be seized ?
    Lawrence
    #175463
    gegsy
    Re: Bosch Dw SRS 56A02GB/B
    Hi Lawrence
    Yes there is a diverter valve, now for the bad news…….. it come as part of the instantaneous water heater p/no 483058. From past experience they seem to weep from “o” ring of heater to sump, damaging the unit and in some rare cases blowing part of the PCB that drives that unit.
    Regards
    That’ll teach ’em to use Salt in the m/c next time! 😉
    #175465
    Er……. why?
    Lawrence
    Yeah why?…
    Lawrence
    #175467
    Lawrence
    Ok cust now wants part fitting ,anyone tell me how ?
    Lawrence
    #175468
    Mark’ll tell you to take the cavity off the base; I do it by turning the machine upside down and take the base off the cavity. 😀
    gegsy
    Hi Lawrence
    This is a guide and you will probably find your own method, but this is the recommended way 🙂
    Unscrew outside door, base panel, angle strip and side panels. Disengage the tension cords from the hinge levers. Unscrew the screws which connect the base pan to the hinge plates. Unscrew the rinsing tank from the rear panel of the base pan. Disconnect the door cable harness from the plug-and-socket connection in the base pan. Place the appliance on its back, carefully remove the base pan and loosen the catch between the level sensor housing and the water softening system. Disconnect the circulation pump with the rubber support from the base pan. Open the base pan until the instantaneous water heater can be screwed off the pump sump. Unscrew the instantaneous water heater. Release the catch on the pump sump and lever the instantaneous water heater off the plug-and-socket connections of the pump sump / circulation pump.
    Good luck
    Greg 8)
    #175470
    Lawrence
    Well did it tonight , what a job thanks Greg I owe you ,Took me 1 & 1/2 hours from first screw to last screw .only managed to confuse myself putting the cord guides back on but got there .
    All in a kitchen that was no more than 1/2 the width again of the D/W .
    Still all good experience ,Incidentally this is the same D/W that had a smell of burning and there is a lot of burning around the connections to the motor area so I wonder if that was it ?
    Anyway job done cust happy and thats what counts
    Once again thanks chaps
    Lawrence
    #175471
    gegsy
    The next time will be easier trust me 😉 you know whats coming now.
    The newer appliances are easier as they have a sheet steel removable base for easy access (2x torx20 screws) 😀
    superfix
    Only the full size ones, slimlines are still a twat.
    #175473
    gegsy
    Yep, I hate slimlines and what you called them is about right but a nice edit from me made it just acceptable 😉
    superfix
    😳 Sorry, I thought it would sensor itself, I mean you can’t write Arsenal, but you can write tw@ 😆 😕
    #175475
    gegsy
    No problems boro. I think another addition to the site/admin censored list is on the cards for that gem 😆
    Dave_Conway
    I thought it was, it is now 😉 😆
    It’s a pain when a censored word forms part of another though, no way round it so Arsenal is now allowed again just for the footy fans but please don’t abuse it 😯
