Bosch Dw SRS 56A02GB/B
Viewing 12 posts - 16 through 27 (of 27 total)
  • #175477
    gegsy
    Re: Bosch Dw SRS 56A02GB/B
    I would arsenal never arsenal do that arsenal Dave
    Greg 😈
    #175478
    Dave_Conway
    #175479
    gegsy
    Couldnt you have picked some other name Dave 😆
    BTW when I type sh!t correctly, I get Chelsea, you may want to check 😆
    Dave_Conway
    I have no idea what you’re on about Greg :rotl:
    Ignore us, just messing about 😉
    #175481
    roly16
    Dave_Conway wrote:I thought it was, it is now 😉 😆
    It’s a pain when a censored word forms part of another though,
    What, you mean like Scunthorpe? 😯
    #175482
    roly16
    Yes it is isn’t it.
    #175483
    Lawrence
    AAARGH!!! shes back again ! poor wash results intermittently she had kept a plate and a mug back for me to see mug looks like it hasn’t been touched and the plate has food in the middle .And of course “my husband says you obviously didn’t fix it properly last time ”
    she is using seperates I gave her a lecture on correct loading but apparently her husband loads it as he doesn’t trust her to do it properly!And of course being the husband he can’t possibly load it incorrectly 😡
    what am I missing ?if anything
    Lawrence
    #175484
    gegsy
    Check – insufficient water level,blocked spray arms,smelly dangly thing hitting spray arm,not heating, poor draining,overloading,tired recirc pump:?
    Just a few in the hat for you 😉
    Seamy
    Found some of these to have blockage & had to take off pump, i find it easier to do this by laying machine on its side or upside down, the string used to tie roasts of meat i find in dishwasher motors frequently, filter obviously hasn’t been in correctly if it gets through. Had these Bosch leak from the two “O” rings above alternating wash valve. Find these to be a bad system, same problems with Smeg & Hotpoint clone. Miele have a great system where all is integrated in circulation pump head.
    #175486
    Lawrence
    right now I am getting somewhere ,She has let me bring it in and I think I know know what is happening.
    When you start the cycle it fills and starts to wash within about tewn seconds there is a low noise and a micro switch click and only the top sparay arm turns ,I fitted a new heat exchange unit on this not so long ago could this be playing up ?
    Lawrence
    #175487
    gegsy
    Lawrence wrote:I fitted a new heat exchange unit on this not so long ago could this be playing up ?Lawrence
    Hi Lawrence, hows you?
    Its quite possible, they are tempremental. Sometimes a small leak from the o ring which attaches the unit to the sump is the culprit.
    Heater exchanger – 483058.
    gegsy
    Hi Lawrence
    What is the full Enr as there are 3 models and 2 different modules
    Cheers
