Bosch E-Nr: WF02865UK/01 E.D 8308600273, W.m
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch E-Nr: WF02865UK/01 E.D 8308600273, W.m
  • #51796
    barryfast
    On spin cycle it will spin from 11 minutes down to 8 then will jump to 1 minute and stop.
    Brushes were gone, fitted new ones but still doing the same thing. Any ideas??
    #309369
    Goatboy
    Re: Bosch E-Nr: WF02865UK/01 E.D 8308600273, W.m
    It’s probably fault code 1.
    I can’t remember if that is pump, motor or heater though 😕
    #309370
    timdowning
    This has been discussed many a time on this site.
    A search should reveal all.
    For me I’ve found that running half a dozen cycles can eventually allow the brushes to seat enough for the module to ‘like’ them.
    If no joy after that you will probably find the fault is due to low insulation of the motor.
    Do remember that the spin on its own never will do a full 11 minute spin anyhow.
    Normally 1 minute left in the display is a heater related fault.
    #309371
    Goatboy
    timdowning wrote:Normally 1 minute left in the display is a heater related fault.
    Thought so 🙂
