Error E25 and check water light on occurring spuradically during all cycles, mainly at the end of each cycle and sometimes at the beginning.
I’ve so far:
1: Checked emptying hose at sink – No blockage.
2; Checked drain sump within diswasher for debris – No blockage.
3: Removed drain pump and tested resistance – 117 ohms.
4: Machine fills fine as long as E25 doesn’t occur at beginning of cycle.
5: Pump works as long as E25 error does not occur.
Just prior to the E25 error the machine time clock seems to stop and then displays the error code. Faulty relay in control panel?
Any ideas to cause?
Regards
Mark
